Console play on Plasma (time lenght)
Discussion in 'Plasma TVs Forum' started by KelvinHT, Jan 9, 2004.
  1. KelvinHT
    KelvinHT
    Dec 31, 2003
    330
    Kent
    +13
    Getting a bit worried about this image burning issue.
    Currently I having a good chill out on my Xbox but as the game (PGR2) has quite a bit of static eliments in the screen (track, rev, Speedo score etc....)
    What is the maximum length of time I should use the Xbox on my Plasma (pioneer 434) ?
  2. funkin
    funkin
    Jan 28, 2003
    41
    London
    I'm personally not worried about PGR2 myself. I've played it for say no more than two hours at a time on my 434. As for the static parts of the game, at the end of the races you go back to the menu to select another difficulty etc. etc. so that will display a completely different screen. I'd say not to worry but i'm no plasma tv expert by any stretch.
  3. KelvinHT
    KelvinHT
    Dec 31, 2003
    330
    Kent
    +13
    THX, mind settled a bit..
  4. gandley
    gandley
    Aug 31, 2003
    5,102
    Paradise Lost
    +269
    Only time to realy worry is if the gauges are white as this will burn quicker.
    best thing to do is after two hours stick a fast moving film in while you take a quick break. and then play on
  5. codlord
    codlord
    May 17, 2002
    283
    Portsmouth, UK
    I've played games for hours and hours before with no problem - as someone else has said, most games even if they have static elements these are not on screen during "loading" or between levels etc.
    As long as your screen has been "run-in" (i.e. used for a hundred hours or so) and you are not running it with silly-bright contrast/brightness settings you should not have a problem - obvioiusly different plasmas will have different issues so just keep an eye on things as you use it to be sure.
  6. KelvinHT
    KelvinHT
    Dec 31, 2003
    330
    Kent
    +13
    thanks guys fro your comments
  7. manc
    manc
    Apr 3, 2003
    151
    19
    I play alot of pes3 and the static pitch radar at the bottom of the screen always leaves a residual image after a couple of hours play - It goes away after a few minutes of normal use tho.
  8. nealgs
    nealgs
    Played PGR2 on a m8s borrowed Xbox for about 3 hrs (went to bed 2pm saturday morning - Doh! ) on our 433MXE - no images remained as longest race was about 7 or 8mins before screen changes to a new menu etc.
    Also have to say that the standard composite picture from the Xbox via the AV reciever to the Plasma is very very impressive. No color bleed of image fuzzyness :) , god knows what component must look like with the hi-def kit:smashin:
    Ogbyte
  9. KelvinHT
    KelvinHT
    Dec 31, 2003
    330
    Kent
    +13
    I have been getting about a 10-15 second video dropout. Does not happen all the time or after the same amout of time
  10. ziocleto
    ziocleto
    Same here,
    played PES3 and PGR2 for DAYS ;)
    Nothing happened, I've got an 400E btw...
  11. KelvinHT
    KelvinHT
    Dec 31, 2003
    330
    Kent
    +13
    Had a call from Pioneer, getting close for a Engineer visit
  12. Luc
    Luc
    Aug 7, 2000
    420
    6 hour stints on Winning Eleven 7 aren't uncommon on my Panasonic 5 series, and i've never noticed anything. I do have the wobble on, and play with as few of the on screen options turned off though...
