Considering Importing Bose Home Cinema System From Us To Ireland
Discussion in 'Home Cinema Buying & Building' started by CUNNINGM, Jun 16, 2004.
  1. CUNNINGM
    CUNNINGM
    Considering buying one of the above in the US, deliver to a mate in NYC who is moving home to Ireland later this year. What are the implications for the current (transformer required?), DVD regions and output signal form DVD to TV (NTSC in US, PAL in europe)
    The system is half the price roughly 1000 dollars vs 2000 euro.
    The only reason for Bose is that I love the tiny speakers.
    Please help !!
  2. Ger
    Ger
    Jun 9, 2003
    1,620
    Ireland
    +83
    More than likely you will need a transformer to step down our voltage for this system (110V in US vs. 220V in Ireland). For the region of the player, it'll most likely be set to Region1, but I am not sure if US players can be changed (through the remote or chipping). Check here: http://www.videohelp.com/dvdhacks.php?dvdplayer=bose for a start. There are other sites that list hacks too (just search in google or yahoo). The NTSC/PAL thing shouldn't be a problem as 99.9% of TVs here support both (even cheapy TVs can support both in my experience).
    Hope this helps.
  3. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,317
    Somewhere in South Yorkshire
    +5,669
    The NTSC/PAL thing may be a problem........many players intended for the domestic US market have NO ability to replay PAL sources - regardless of any region-free mods. So, if true, you may be limited to US imported DVDs (plus, if you can de-region it, Japanese) but may be excluded from the vast majority of European or Australian (etc) titles.
    And, whilst not suggesting you discount it completely, there are many who believe that Bose equipment does not, in reality, live up to its marketing. Yes, it looks good, but there may be more important factors.
    Whilst we could debate ad nauseam the materials used for the speaker cones and so on, the major points I would make are:
    > The Bose Acoustimass Unit is used to reproduce frequencies somewhat higher than in a more traditional subwoofer i.e. extending into the low midrange (to offset lack of ability for this in the satellites) which tends to make its direction/position more evident as you listen.
    > Bose satellites can ONLY be used with a Bose Acoustimass Unit. So you lose the ability to upgrade to a better subwoofer if you decide that's what youd like to do.
    > Bose Acoustimass can only be used with Bose satellites, so, again, you lose a possible upgrade path.
    > There is little in the way of tuning of frequency response, so you are at the mercy of your room acoustics, to a greater degree than with many sub/sat combinations.
    Just FYI.
  4. CUNNINGM
    CUNNINGM
    Thanks to both of you for your advice.
    I am very much a novice when it comes to home cinema systems.
    The only reason I am considering Bose is for the small speakers.
    I have prewired my sitting room (5.5m x 3m) for speakers in 3 corners all back to the tv location and all I really want is a good system with the smallest possible speakers. Certainly the vibes I am getting is that Bose is not all that brilliant relative to the serious overpricing - especially here in Ireland and probably UK too. I did want the smallest speakers possible ideally with wood effect but I have had no luck. In fact I might start another string on that topic.
    Many thanks again.
  5. LV426
    LV426
    Jul 14, 2000
    13,317
    +5,669
    If you want small, but (IMO) vastly superior to Bose, then take a look at - for the satellites ENERGY TAKE 5.2s. They are only fractionally larger than the "twin" Boses; obviously quite a bit bigger than their tiny single items. And for a Sub - not the matching Energy item, but something like a REL QUAKE.
    You should be able to demo these items at a Sevenoaks branch. And they will sell you a mix & match setup.
  6. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,132
    83
    Over the Hill & Far Away
    +119
    Or how about kef eggs, Anthony Gallo micros... etc etc
    Good luck
  7. PaulaB
    PaulaB
    Mar 6, 2002
    242
    Northamptonshire
    DOn't forget the mission fs2av's
  8. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    22,417
    2
    In a secret location with Jennifer Lawrence
    +9,112
    Thread moved to All in one systems, slightly more appropriate than DVD talk.
