Considering 46WM48
Discussion in 'General TV Discussions Forum' started by synaptyx, Jun 6, 2005.
  1. synaptyx
    synaptyx
    Hi all, first post! :hiya:
    We're moving house soon and my 4 year old Hitach 32" CRT has just given up. Pathetic really, my last CRT lasted 14 years (a 21" Sammy!). I have been comparing bang for buck and I've decided on DLP for the HD compatibility and the sheer size. This has created a small controversy among friends who all seem to prefer plasma/LCD. I'm not a fan of the LCD's I've seen and couldn't afford a good sized screen anyway. I'm not considering plasma as I haven't seen an HD compatible at a decent (i.e. cheap :D ) price. Being a tight arsed Scotsman, I briefly considered the cheap LG, but reading the threads here convinced me to shell out the extra few hundred for the Tosh 46WM48 for the new place.
    Now all I have to do is convince the wife. :lease:
    I haven't been able to look at a DLP screen in the flesh yet, basically because there are none locally and I'd have to make a trip to Edinburgh to Glasgow to see some. Anybody in Ed/Gla recommend a place to look at DLP screens?
  2. soni
    soni
    Oct 22, 2004
    557
    Kent
    Hi Synaptyx - Wellcome to the forums!! :)
    I previously owned the Tosh 46WM48 and it is a very good TV which displays stunning pictures with pinpoint sharpness and clarity, unfortunately this model has a problem with motion blurr (however not all owners have experienced this so i wouldn't let this put you off) and therefore returned it for the Sammy SP50L7 which i am very happy with indeed. I would recommend taking along some test discs to somewhere like Comet - you should be able to find somewhere in Glasgow/Edinburgh - a retail park would be ideal - that way you can try the Tosh in Comet - and then pop nextdoor to Currys and demo the Sammy 46L3 & 50L7!!! :thumbsup:
  3. synaptyx
    synaptyx
    Hi Soni,
    Thanks for the welcome and the info!
    Trying to keep the costs down so can't afford to go above £1400. Even that's a push so I think I may be pretty limited to what I can buy. Will take a trip to Edinburgh at the weekend I think. :)
  4. soni
    soni
    Oct 22, 2004
    557
    Kent
    Synaptyx:
    I've got an idea that the Tosh is still up for 1999 in Comet. However, if you can get into Costco, its up for £1527 (i think).
    You could probably pick it up for even cheaper on-line. Take a look at the following link as an example of the price difference!!
    http://www.buyyourav.com/product_details.asp?prodID=1365
    You will certainly appreciate the PQ of the Tosh over the LG. Also, I’ve got a strange feeling that the LG isn't capable of receiving Sky HD when eventually broadcasted. Take a look at the following link – read JohnWildes post dated 3rd May.
    http://www.avforums.com/forums/showthread.php?t=208398&highlight=lg+hd
    Trust me – if its out of the LG and the Tosh –then go for the Tosh – it gives a superb looking picture and you won’t be disappointed. If you can’t stretch that little bit more – then wait until prices drop – you will be defeating the object by getting the LG if you want HD.
  5. pantages
    pantages
    Jan 7, 2004
    944
    2
    Boston
    +59
  6. synaptyx
    synaptyx
    Thanks folks!
    It looks like it's going to be 12 weeks :( before I can go ahead with getting a new TV. 'Er indoors doesn't want to have to get it now and move house with it. I'll keep an eye on the Tosh and the forums and see what I can manage closer to the time. :)
  7. Mark_a
    Mark_a
    May 27, 2005
    3,064
    +612
    That might be a blessing in disguise as Toshiba are supposed to be launching replacements for the 46" and 52" with three new models, 46", 52" and 62" around September time. Pretty much the same as the existing but with twin Freeview tuners and two HDMI inputs.
    http://www.homecinemachoice.com/cgi-bin/shownews.php?id=7807
    Regards
    Mark
  8. soni
    soni
    Oct 22, 2004
    557
    Kent
    That will almost certainly push the price of the existing models down, down, down!!! :)
  9. pantages
    pantages
    Jan 7, 2004
    944
    2
    Boston
    +59
    Very interesting! Toshiba must have confidence in their product to update the range and launch a 62" so soon. No doubt they will have ironed out any 'teething' problems. As for price, my guess is that £ for £ the new models will be cheaper than the existing models, although there will be some good bargains to be had before the new ones are available.
  10. synaptyx
    synaptyx
    Well, 5 and a half months later... I've just ordered a Sammy SP50. It should be delivered tomorrow. :) Can anybody recommend a multiregion DVD player capable of upscaling?
  11. pantages
    pantages
    Jan 7, 2004
    944
    2
    Boston
    +59
    I use Pioneer 868 HDMI output which is a stunning machine.
  12. synaptyx
    synaptyx
    I've just skint myself buying the TV, but thanks for the recommendation. I was thinking sub £200. ;)
