Conponent On Pioneer Dv05 Elite
Discussion in 'Blu-ray & DVD Players & Recorders' started by BIONIC MAN, Jun 27, 2002.
  1. BIONIC MAN
    BIONIC MAN
    Jun 26, 2002
    1,002
    Nasa
    +45
    HI TO ALL NEED SOME HELP PLEASE
    WHEN I TRY AND CONNECT MY PIONEER DV05 ELITE DVD PLAYER TO MY 32 TOSH TV VIA COMPONENT THE SCREEN HAS A GREEN TINGE TO IT ? ? WHY ,
    IS IT DUE TO THE FACT THE DV05 ELITE IS A NTSC MACHINE & THE
    TV IS PAL ( THE PLAYER IS MULTIREGION WITH SUDOPAL MOD )
    SO PLEASE IF ANYONE CAN HELP
    THANKS FOR ALL YOUR TIME
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Does the TV actually support Component in or have you, accidently, connected it to some RGB input?
    PS: Please switch off your CAPS. Thanks.
  3. BIONIC MAN
    BIONIC MAN
    Jun 26, 2002
    1,002
    Nasa
    +45
    The TV is the Toshiba ZD3209D which has the component on the back of the TV , which the manual advise connect a dvd player
    Also sorry about the caps ,
  4. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,465
    United Kingdom
    +1,936
    The Caps Lock on your keyboard, capital letters is considered to be SHOUTING on the web!!:)
  5. BIONIC MAN
    BIONIC MAN
    Jun 26, 2002
    1,002
    Nasa
    +45
    All sorted on the caps now , Sorry to all but I'am new ,
    So any help with the problem with my set up
    :D
  6. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,465
    United Kingdom
    +1,936
    Does it pick up an NTSC signal ok? If it does then I assume its to do with the Pal mod thats causing the green tinge.
  7. BIONIC MAN
    BIONIC MAN
    Jun 26, 2002
    1,002
    Nasa
    +45
    I think the TV does not pick up a full ntsc signal ,
    thats why the player had the sudopal mod which Techtronics done ,
    I got the TV as it had the component just for my dvd player and it didn't work using it , so I have the s-video lead going into the front of the TV , Nightmare
  8. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,465
    United Kingdom
    +1,936
    Strange, most TVs nowadays can pick up an NTSC signal via S-Video, Scart etc
    Double check that the dvd player is switched to NTSC only, play a Region 1 disc and connect it via S-Video and then component and see what you get. If you get something via S-Video then in theory it should work for the component input as well.
    Cant suggest anything else except maybe a new TV or dvd player!!
  9. RichardA
    RichardA
    Bionic,
    The Component output will not be affected by PAL or NTSC or PAL60 - they all refer to colour encoding used for composite video and S-Video only.
    Pretty sure it has nothing to do with 50Hz or 60z, or R1 or R2 material if you can get it all running with S-Video.
    A green tinge on component usually indicates that a component signal is connected to an RGB input on the TV - is there a menu selection for RGB or Component for that input on the TV ? (it may well be a hidden or service menu)
    With this (Component going into an RGB input) you will get a green colour cast to everything and muddy browns.
    If it was the other way round (DVD player outputting RGB into a TV expecting Component) you would get a very Purple picture.
    It might be worth searching or posting in the TV section to see if anyone knows about any menu stuff - don't forget to specify which exact model Toshiba you have!
    Hope this helps.
