Connectors for wire?
Discussion in 'Home Cinema Buying & Building' started by davemcqueen, Jun 24, 2015.
  1. davemcqueen
    davemcqueen
    Jun 24, 2015
    4
    Edinburgh
    The sound on my home cinema keeps cutting out and I've determined it's poor connectivity between the bare wires and speaker terminals. Is there a some sort of connector I can buy for the ends of the wires that will then give a better connection?
  2. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    How did you determine that was the cause ?
  3. John7
    John7
    Aug 6, 2004
    2,846
    +995
    Assuming you have "standard" 4mm speaker terminals (not the cheap spring clip type) these, or similar are what you need. They have a screw fixing for easy connection or can be soldered if you have the skill/equipment, for a more reliable connection
    Shark 4mm Banana Gold Plated Short Plugs | Maplin
  4. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    unless you have blu-tacked the wires on i suspect the problem lies elsewhere
  5. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    can you post a picture, and also more information regarding the setup
    do all speakers cut out ?
  6. PSM1
    PSM1
    Dec 20, 2008
    26,285
    +5,443
    I would agree with Aclass. A banana plug just adds another connection in the system so technically worse than bare wire.
  7. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    Think we need some more information
  8. davemcqueen
    davemcqueen
    Jun 24, 2015
    4
    Edinburgh
    Hi Guys. These are the connection terminals on my speakers. I can determine it's the connection because there is no sound in a couple of speakers, unless some movement of the wires. I actually soldered the bare wires a couple of months ago as I thought that would fix this infrequent issue permanently, but it hasn't. So now I am thinking some proper connectors on the end to fit the kind of spring clip on the speakers instead of bare wire. Thanks for all replies.
  9. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    Aha, you can't use banana connections .
    Strip back more speaker cable and fold back on itself so spring clip makes a better contact .
    How are they connected at avr end ?
  10. PSM1
    PSM1
    Dec 20, 2008
    26,285
    +5,443
    Could be an issue with the spring clip more than the cable. Can you undo the backing plate to see if anything is loose behind.
  11. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    How many speakers does it occur on ?
  12. davemcqueen
    davemcqueen
    Jun 24, 2015
    4
    Edinburgh
    2 out of 5 speakers. Thanks
  13. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    Which speakers of the 5.1
  14. davemcqueen
    davemcqueen
    Jun 24, 2015
    4
    Edinburgh
    Right now it's the Centre and Rear Right. Thanks
  15. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    Swap rear right and rear left around and see where problem remains
  16. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,923
    The Borders
    +3,570
    Don't discount there being an issue at the other end of the cable and or with your Amp.
    As others have said no need to add Banana or any other form of additional connection and the trick now is to track down where the problem lies.
    A pic showing the rear of the Amp and Spks with cables in place may be handy too.
    Joe
