Connectiviy Help Needed by Technophobe LCD-DVDR HCSys
Discussion in 'Home Cinema Buying & Building' started by skthecat, Sep 14, 2007.
  1. skthecat
    skthecat
    Aug 27, 2007
    29
    Hi, this is related to an earlier thread - Sony Dav-DZ231 Home Cinema
    I have now taken that piece of junk back to curry's!!!
    My problem is how to connect the items together listed below
    Std Sky Box
    LG 37inch LCD (with freeview Not Used)
    Cyberhome 1600 DVD Recorder/Player
    Goodmans
    GHC304DVDR Home Cinema (((The DVD part of this does not work)))
    I will want to use the Goodmans as a 5.1 Amp and radio tuner
    I need to know how to configure it all bearing in mind I am a Techno Phobe, I really could do with a connectivity Diagram and instructions
    Also are RCA connections called anything else?
    At Xmas I will be getting Sky HD so I am aware most of the above will become redundant.
    Best options please,
    Hope to Hear from you all soon :lease: HELP
    sk THE cat
  2. THERAAAVEN
    THERAAAVEN
    Jan 31, 2006
    587
    ruislip
    +10
    What connections are there on the goodmans?
    personally think you would need a new system to be able to
    get all connected up - especially when you get sky
    lets assume the goodmans only has one aux input?
    sky to tv = scart
    dvd to tv = scart or component if dvd has it
    then a phono cable from tv to goodmans
    sky hd would use the hdmi come xmas
    if the goodmans has an optical/digital coax and the dvd player has the same i would use that for sound from the dvd - but not sure if it does
    a much better idea would be to get something like a yamaha av61 / samsung htas1 / sony's many type of seperate units and use that just for sound
  3. skthecat
    skthecat
    Aug 27, 2007
    29
    Hi. The items have the following connections,
    The Cyberhome has the following on the back;
    Antenna in
    Antenna Out
    Coaxial Out-Digital Coaxial Audio
    Audio R/L Out- Analogue 2 channel White/Red
    Video Out-Yellow
    Ext2 Aux-Scart Socket 2
    S-Video Out
    Ext1 Scart Socket 1 to connect to tv
    It also has on the front
    DV in i Link / DV Socket
    Audio L (White)
    Audio R (Red)
    Video In 2 (Yellow)
    The Goodmans has the following
    TV Antenna in & Out
    Cr/Y/Cb out
    S-Video 1 In
    S-Video Out
    RCA Video 1 in
    RCA Video out
    RCA Audio 1 in (Left & Right)
    RCA Audio out (Left & Right)
    Coaxial (Digital Out)
    21 - pin Scart socket (In)
    21 - Pin Scart TV Socket
    Then all the Speaker terminals/MW & FM Ariels
    On the Front
    S-Video 2 Input
    Video 2 Input
    Audio 2 Input
    Does this help sort a diagram for
    Sky--> DVD R-->Goodmans HTS (DVD tray busted)--LG
    LCD Tele with 3 scarts
    VCR, not sure of its connections available
    Regards
    sk THE cat
