Connectivity
Discussion in 'Digital TV & Video Players & Recorders' started by Reefman, Apr 26, 2002.
Tags:
  1. Reefman
    Reefman
    Apr 22, 2002
    34
    11
    County Durham
    I've just bought a Philips Dolby Digital TV to find that only ext1 will accept the 5.1 signal input on co-ax. I therefore need to connect both DVD and sky+ to ext1 on TV. I may need to heve both units powered at the same time but when they are connected via a scart doubler I just get interference. I think I need a switched scart, are there any available that are RGB compatible, preferably automatic so that they switch to the last powered up device or at least prioritise one of the inputs.
    I've also had to get a digital optical - to digital co-ax converter to link sky + to TV which I also need to switch as TV has only 1 digital co-ax connection. Any solutions ?
    Is there anything around that could do both at the same time?
    Can I get a 9v dc 300ma output from the interface on the back of sky+ box, if so which pins?
