Connectivity question.
Discussion in 'AV Receivers & Amplifiers' started by Garrett, Oct 21, 2004.
  1. Garrett
    Garrett
    Apr 21, 2001
    42,796
    2
    167
    The best thief you'll never see.
    +8,000
    If I get a surround receiver and only want it for the surround and want my Audiolab amp to run the front 2 speakers for the music a when in surround again for the front two. How would I connect the two up?
  2. lostprophet
    lostprophet
    May 11, 2003
    288
    Not the light side....
    +12
    AV reciever front pre-outs to an input on the 2ch, connect fronts to 2 ch then rears centre etc to AV amp, cd player to 2 ch and multi channel sources to AV amp.
    Hope that helps
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    If audio lab has processor inputs connect AV preouts to these so you bypass the preamp in the audiolab so you dont have to mess around with volumes nobs on both every time you want to use them
