connectivity question !
Discussion in 'Cables & Switches' started by will-uk, Jul 19, 2004.
  1. will-uk
    will-uk
    Hi all,
    I recently purchased a panny viera and got a DMRE55 into the bargain. I already own a Sony DAVS880.
    My question is, I would like to play DVDs via the DMRE55 from now on, however I would still like to have the Sony as the audio source. I have purchased an optical cable which Ive used to connect the Sony to the DMR, and I also have an audio cable between the Sony and my Sky box.
    As it stands, I can get Sky audio through my Sony setup, but when I play a dvd through the DMRE55, the audio comes from the plasma speakers and not from the Sony setup.
    Any ideas what I need to do ? :lease:
    thanks for any guidance :smashin:
    cheers
    will
  2. will-uk
    will-uk
    ahem, bump :confused: :clown:
  3. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,906
    I don't know much about Sony DAV's but do you have to assign the optical connector on the DAV
  4. Seanjackdan
    Seanjackdan
    Hi -Will,
    Did you ever get this sorted, as I will be have an identical set up to you shortly, and want to do exactly the same thing, but don't know how to do it !!!!!!!
    Please help !!!!!!!!
    Sean......................
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    i think you need to set DMr-E55 to optical out and select the optical input on DAV, :rtfm: try the DAV manual guys.
