Connectivity PW7-VSXC502-E55-PS2
Discussion in 'Plasma TVs' started by Bobby_Dazzler, Apr 25, 2005.
  1. Bobby_Dazzler
    Bobby_Dazzler
    Hi All
    I need a little help here !
    I have just set up my lovely pwd7 with a JS Tech rgb - vga convertor
    And need advice on connecting the rest to it!
    I have a Pioneer VSX C502
    http://www.superfi.co.uk/index.cfm/page/moreinfo.cfm/product_id/2114
    The question I have is on the sound side.
    The vsx c502 has 4 scart inputs which will be assigned to
    DVD Recorder
    PS2
    Sky +
    JS tech rgb - VGA convertor - PWD7
    it also has 2 optical inputs that i will connect to the sky + box and the dvd recorder.
    The question is ... what about sound for the PS2 ???
    I have no optical inputs left on the VSX c502 and no phono inputs !
    However I do have a coax input on the VSX but the ps2 doesnt have one!
    Andy ideas?
    Bobby
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    PS2 will sound sound down the Scart (stereo) so you will have sound (pity the E55 has optical only) you can get a optical to COAX converter for £25 ish see lektropacks
  3. Piers
    Piers
    Dec 11, 2002
    1,971
    Shropshire
    +227
    Having read the spec from the link you provided it looks that it has 4 analogue audio inputs and by my reckoning all 4 of them are currently unused.
