Connectivity......Please help. How is everyone connected.
Discussion in 'Plasma TVs Forum' started by nathanf, May 6, 2005.
  1. nathanf
    nathanf
    Mar 17, 2003
    52
    When I was using my old 28'' CRT, It had 3 Scart connections on the rear and also phono connectors for AV out (I dont know the actual name for them)
    Everything was fine. I could switch from NTL to DVD to VHS to Games console withOUT having to mess with wires at the back.
    I now have a PW5 with the RGB/Component board. Im keep having to mess around with wires at the back.
    Can someone tell me if there is a way to have everything simultanoiusly connected?
    Will these £60 Vivanco/Hitachi (argos) splitter boxes work? Has anyone tried them? Or if not, please suggest how I can connect everything at the same time.
    Someone has told me I have to buy a VGA to Scart converter and use the PC input for the VHS???
    :lease:
  2. Taz69
    Taz69
    Apr 15, 2002
    3,403
    Bristol
    +343
    Hi m8, it would help if you listed the items you have and model numbers etc, if they have scarts only or component leads aswell.
    cheers
    Taz
  3. nathanf
    nathanf
    Mar 17, 2003
    52
    pw5 -
    1 x svideo
    1 x composite
    1 x rgb
    Samsung Set Top Box -
    2 x scarts
    JVC-TH-V70R
    1 x Scart
    1 x S-Video out
    1 x Video out
    1 x Audio in
    1 x Digital Audio in
    JVC SVHS
    2 x Scart
    RF and Coax in/out
    Xbox
    1 x Scart out (The dig. Audio comes through the scart lead with a DA connector)
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    SAMSUNG & JVC to JS tech RGB>VGA converter, Xbox (with HD cable) to component, S-VHS deck to S-video input JOB DONE
  5. Taz69
    Taz69
    Apr 15, 2002
    3,403
    Bristol
    +343
    Just about to reply HD, lol, but on the 1st post you say it is a component board then you say its a Composite board, which is really the lowest of low and you want to stay away from that if poss.
    Taz
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    the 5 series video board is basically the same as the "dual slot" for 6 and 7 series screens ie RGBHV/Component shared and S-video/composite shared so can only use S-video or composite and Compaonent (not 100% whether RGBHV was included or not....)
  7. nathanf
    nathanf
    Mar 17, 2003
    52
    Thanks you guys.
    The board I have has RED WHITE AND YELLOW (is this called AV?) and S-Video.
    (They cannot be both plugged in at the same time)
    Then it has 5 other phono type connections labeled "Component/RGB" (VD, HD etc...)
    I have no speakers connected to my pw5 as I use the surround speakers to watch the TV.
    How many items can be connected to the JS converter? Would I be able to connect phono cables from the JS to the DVD, if it was connected to my STB..
    In other words, can the audio out be routed to the DVD instead of the TV?
  8. nathanf
    nathanf
    Mar 17, 2003
    52
    Whats an HD cable for the Xbox? :confused:
    Thanks for trying to help also?
  9. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    component cable or "Microsft HD pack" not sold in europe officially. but lik-sang etc do component cables for Xbox.
  10. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    OK board is as i thought same as dual slot 6 and 7 series. JS RGB>VGA has on scart input and 1 VGA output as well as stereo audio out, it has only one scart but if you connect DVD>STB>JS it should work fine (may need a scart switcher ala JS MSC £50 or £10 for a manual one in argos.) so scart into JS VGA to screen audio to DVD
  11. nathanf
    nathanf
    Mar 17, 2003
    52
    Will the quality of the DVD be reduced if its running through the STB.
    What will the scart switcher be connected to?
    Im not retarded I swear, I'm just confused.
    Ive checked the site you posted BTW and they have the cable you were refering to, allthough it isnt in stock.
    [​IMG]
  12. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    thats the fella........ OM SCart switcher issue
    DVD>switch
    STB>Switch
    Switch> JS RGB to VGA box
    RGB to VGA> Plasma
    Make sense?
  13. nathanf
    nathanf
    Mar 17, 2003
    52
    Perfectly :) :cool:
    Are you definatly sure I will be able to run phono cables from the JS RGB>VGA to the Audio In on my DVD player?
    Also, where is the best place to get the JS RGB to VGA box from?
    Thanks HornyDragon, you really cleared this up for me. :thumbsup: :thumbsup:
  14. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    If you cant send the audio from the JS box to the Audio in on DVD player (must have audio in!) I will eat my hat...........
    JS sell direct, AV sales sell them, as do loads of places..........
  15. nathanf
    nathanf
    Mar 17, 2003
    52
    Great Stuff!
    My VHS does NOT have a S-Video out.... Can I use a scart to S-video cable?
    Or should I use a scart to red/white/yellow cable?
  16. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    if it is an S-VHS deck use scart to S-video cable (4 pin mini DIN) if its not S-vHS sue composite (yellow RCA cable)
  17. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    nathan..i just put a JS in the classifieds
  18. nathanf
    nathanf
    Mar 17, 2003
    52
    Its defo an S-VHS deck, but with NO S-Video out just 2 scarts.
    Will a monster scart to svideo cable work? I think they are about £14.99 from currys.
  19. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    yeah but dont go over board pricewise...
  20. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
  21. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    cheers horny mate :)
