"Connectivity" 2
Discussion in 'Desktop & Laptop Computers Forum' started by danny-p, Mar 28, 2003.
  1. danny-p
    danny-p
    I was just wondering how to connect my pc to my plasma and to run sound through my amplifier.
    The pc is a Pentium 3, 800 Mhz, with a 64 meg G-Force 2 mx400 agp video card with "onboard sound".
    My plasma is a panasonic th42pw4b and the amp is a sony TA-VA777es.
    I will be running on windows xp which i believe can be set at widescreen.
    Hopefully it will just be a good quality sound card and a cable from the back of the pc to plasma's vga imput??
    Danny-p
  2. petrolhead
    petrolhead
    Mar 29, 2002
    4,489
    71
    Newcastle
    +82
    For Video the Radeon 9000 would do a good job, no fan so quiet. Approx £50 from Dabs
    For decent sound M-Audio Revolution 7.1 £88 from Overclockers
  3. danny-p
    danny-p
    well thats video and audio sorted out ..cheers petrolhead..
    Any recommendations for the "vga"cable and if this goes direct from back of pc to back of plasma or via a converter?
    Danny-p
  4. petrolhead
    petrolhead
    Mar 29, 2002
    4,489
    71
    Newcastle
    +82
    I would have thought if the Plasma had a VGD D connector then connect direct form PC to Plasma. Making sure you use the correct resolution and refresh.
    If anyone else can just confirm this........
