Connections
Discussion in 'Plasma TVs' started by rdt123, Feb 18, 2003.
  1. rdt123
    rdt123
    Dec 14, 2002
    1,413
    Busting out a restaraunt in Queens, NY
    +33
    HI all
    Whats the best way ofconnecting a philips 963 to a panny rca board. I think the dvd is component yuv wherehasthe screen is component RGB. Aren't thesedifferent signal types?
    Would i need an adapter to get them to talk to each other?
    cheers
  2. jmack
    jmack
    just connect the component leads out of the dvd to the imputs on the plasma , in the setup menu on the plasma select component not rgb,
  3. rdt123
    rdt123
    Dec 14, 2002
    1,413
    +33
    Thanks a lot,
    so i just need a rca to rca component cable right?
    can you recommend one
  4. jmack
    jmack
    any good quality one will do
    have a look in the classifieds thread
