Connections
Nape Dog
Hi I am preparing for when i am able to set up my new home cinema in the future. just a quick question. can i use this cable http://www.tvcables.co.uk/cgi-bin/tvcables/PGV372.html from sky box scart to component in on the receiver. then use the component out from receiver to tv? would i also need phone leads to send the sound or will this cable do it all? i only have a basic sky box so no optical out on it only the red/white phonos.
thanks
bsuttie
No, Scart cables are not reversible. That is a component to Scart cable, not the other way round.
You would also need something to convert RGB to component unless you have an unusual SKY box that has component out.
regards
Brian
Nape Dog
regards
Brian
thanks
so i would have to run a scart into the tv and phonos to the receiver then? is there any other way to run sky via the reciever so i don;t have to run direct to the tv?
bsuttie
Nape Dog said:
thanks
You could go RGB to component to A/V amp
RGB to S-video to A/V amp
Composite to A/V amp
First would be best quality, last would be worst.
What other sources do you have?
Brian
Nape Dog
Brian
my plan is to connect my dvd to the receiver via component and optical then run component from the receiver to the tv. i just need to get the sky connected and was hoping to be able to do this via the receiver so that i can have just the one cable going into the tv.
can i get a scart to component cable then?
does component carry sound aswell or will i need to run phonos from the sky box to the receiver?
sorry i am a complete newb to this stuff.
bsuttie
OK, if you want the best quality option you need something like this to convert your Sky box RGB to component. This also splits out the audio which you would connect to a stereo input on your A/V amp. You could alternatively connect the phonos from the SKY box, whatever is more convenient.
regards
Brian
Nape Dog
regards
Brian
thanks Brian but that seems a little more then i would have hoped to spend. i think i will have to stick to my original plan for the time being.
thanks for all your help anyway:smashin:
Similar threads
The Best Movies and TV Shows Coming To Amazon Prime Video in August 2020. Tom's Thumbs.
