connections
Discussion in 'Blu-ray & DVD Players & Recorders' started by twinkle, Feb 1, 2005.
  1. twinkle
    twinkle
    :mad: i have panasonic tv 1 scart, a grundig sky box 2scarts,a panasonic vcr 2scarts,a medion dvd 1 scart & A NEW matsui dvd recorder. iwould like to connect them all together. if not are there alternatives. please help.
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,702
    Warwick
    +2,578
    I am assuming your DVD recorder has two scarts - it's not a brand I have much experience with but it is probably based on a Philips reference design. Whatever you are quite limited by only having one Scart socket on your TV. I suggest you connect by Scart cable as follows:
    VCR Input/Output >>> VCR input on Sky and then TV Out >>> Input on DVD Recorder >>> then Output >>> TV Scart Input
    This will allow you to record onto VHS whilst watching a DVD, record Sky onto DVD, watch Sky. When not using units I suggest putting them to standby to reduce the likelihood of interference (copy protected VHS tapes will not pass through the DVD recorder properly when it is 'on').
    I suggest getting rid of the Medion unless it offers significantly better playback than the new DVD recorder. If you really want to keep it you can buy a 2 into 1 Scart box (you can get cheap ones from Argos - spending more probably isn't worth it with the components you have).
