connections?
Discussion in 'Blu-ray & DVD Players & Recorders' started by bigtank, Nov 14, 2004.
  1. bigtank
    bigtank
    May 21, 2002
    188
    belfast
    hi all
    looking advice on best way to connect my TV/DVD RECORDER/FREEVIEW.
    TV-TOSHIBA 32ZT29B (3 SCARTS PLUS COMPONENT)
    DVD RECORDER-PANASONIC DMR55 (2 SCARTS PLUS COMPONENT)
    FREEVIEW BOX-SONYVTX-D800U ( 2 SCARTS)
    please help
    p.s.
    I don't use the intergrated freeview tuner on the toshiba as it is crap. :lease:
  2. Stompa
    Stompa
    Feb 9, 2004
    74
    +7
    Out of curiousity why do you think it's crap?
    I have one of these and it seems fine.
    Stompa
  3. jonslon
    jonslon
    I'd suggest:
    TV ---component--- DVD RECORDER ---RGB scart--- FREEVIEW BOX
    That way you get best possible display on the TV, and best output from the Freeview box to the DVD recorder, allowing you to watch the Freeview through the DVD-R to the TV.
    Good luck....
  4. bigtank
    bigtank
    May 21, 2002
    188
    belfast
    the intergraded freeview tuner is very slow and suffers from signal lost were the sony unit does not.
