connections
Discussion in 'Plasma TVs' started by cruncher75, Dec 4, 2003.
  1. cruncher75
    cruncher75
    Nov 1, 2003
    1,252
    southampton
    +95
    hi what connections do u use for sky/ntl and dvd i have scart/s-video lead for dvd and scart/s-video pluged into a think its called a bnc socket into the plasma for ntl as i only have one s-video socket is it normal to use this bnc socket
  2. nealgs
    nealgs
    Hi cruncher75,
    what plasma you connecting everything to?? - DOH!, just read you sig, same plasma as us :)
    Do you have the PDA-5002(?) board in you MXE??
    We use a JSTech SCART RGB to Component converter (RGB2YUV).
    The DVD player is daisy-chained to the Amstrad Sky digital box, which then feeds to the JSTech converter.
    We use our Yamaha reciever to switch video, by feeding the component out from the JSTech into one of the component ins on the reciever.
    This receiver then feeds a component cable direct to the 3 BNC connectors of the plasma (433MXE).
    regards
    Gary
  3. cruncher75
    cruncher75
    Nov 1, 2003
    1,252
    southampton
    +95
    i got my video going into my sky
