connections to sanyo z1 What doi need
Discussion in 'Projectors, Screens & Video Processors' started by RATMARK, Mar 21, 2003.
  1. RATMARK
    RATMARK
    i need to connect
    1 sky + box
    1 dvd
    1 free to air box
    1 computer
    to a sanyo
    is their a box that i can connect the tv based items into and then run a component to the sanyo etc
    and run the comp direct to the sanyo
    or is their a box that everything can go thro and run to sanyo via a computer cable connection
    ie only one cable feeding all data into pj
    as you can see im not fully up to speed on all the connections
    any advice
    thanks
  2. R32
    R32
    what are you using for the audio?
  3. RATMARK
    RATMARK
    marantz sr5200
    i
