Connections to extron
Discussion in 'Home Cinema Buying & Building' started by steve in derby, May 12, 2005.
  1. steve in derby
    steve in derby
    I want to connect a panasonic m40 video camera to an extron system 8 plus.
    Using video output on camera into extron switch input.
    This will want to be outputed to an infocus projector.
    I am confused at what cable between camera and extron (bnc conections). :lease:
  2. Blaze01
    Blaze01
    Steve,
    From what I remember the System 8 has BNC inputs and and outputs but does not convert the video signals.
    If you are using Composite Video then you can pass through the any channel but I would use the RED. If you are using S-Video (YC) then use the RED and GREEN, if your camera outputs (YUV) Component then go in on channels RED,GREEN,BLUE.
    Remember as the swicther does not scale or scan the video signal so the input must match the input in the display device. E.G YUV in on switcher must go to in YUV on the display device.
    I hope this helps.
  3. steve in derby
    steve in derby
    Cheers. That helps me out. :hiya:
