Connections to AE700
Discussion in 'Projectors, Screens & Video Processors' started by 1Jazzy, Jun 7, 2005.
  1. 1Jazzy
    1Jazzy
    Hi there,
    I am going to be an owner of an AE700 in a few days and I am currently planning all the different connections that have to go into it. I would appreciate a little help connecting my DVD player to the projector. I own a Marantz 4100, which has got composite, S-video and SCART (RGB through SCART) outputs. I also own a Marantz SR5500 receiver. Which of the following 'picture paths'/connections is best?
    1) S-video to receiver => receiver upconverts to component => connect component to AE700
    2) RGB through SCART => directly to AE700 -> can the AE700 handle RGB signal well? I need at least a 3m SCART-SCART cable for this. Is running a long SCART cable a bad idea?
    I know that the AE700 has got a decent deinterlacer/scaler for the money, so I would like your opinion.
    (FYI, I will also be running a DVI-HDMI cable from my PC, sending 720p signal, but I need the flexibility/practicality of the separate DVD player, for the wife etc.)
    Many thanks!
  2. pmc
    pmc
    Oct 18, 2004
    1,411
    +109
    I would just run the DVD scart to the AE700 scart. That's what I do and the pictures great, plus you get aspect control signals through the scart. 3m isn't that long as long as you get a decent cable.
    Also you could connect the PC to the HDMI imput at the same time. No need for compromise.
