Connections: PS2 to Pio MXE
Discussion in 'Plasma TVs Forum' started by Epoman, Dec 22, 2003.
  1. Epoman
    Epoman
    Jan 3, 2002
    3,128
    71
    On my PC
    +85
    I'm having a bit of a thick moment.
    Is it possible to connect my Sony PS2 to my Pioneer 433 MXE plasma? I just can't see how it should be done. The PS2 lead has a scart, so how does it connect to the plasma?
    The plasma has the following connections:
    mini D-sub
    BNC jack's - used by my DVD for component
    DVI-D - used by my PC
    S-video - used by my amp for on screen display
    RCA's - for sound presumably?
    BNC jack - this apparently takes a composite video output jack.
    Do I need to connect via the spare bnc jack? If so how?
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,705
    The Borders
    +3,075
    Epoman
    If you want a decent image purchase a PS2 Component video cable and connect to the Plasma via your AVR-3802.
    You'll need to rewire your DVD via the AVR-3802 also - it may be worth testing you are happy with this before you do it permanently; though I must say I find the video circuitry on the AVR-3802 is pretty clean.
    Best regards
    Joe
  3. Epoman
    Epoman
    Jan 3, 2002
    3,128
    71
    On my PC
    +85
    Hi Joe
    I don't have a spare set of component inputs. The amp has 2 sets of component - one will be used by the DVD and the other by my JS Tech YUV2RGB box for Sky.
    Any other way of connect ing the PS2?
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,705
    The Borders
    +3,075
    Hello Epoman
    You could always wait until mid Jan 04 when we have our first shipment of the Zektor YUV switches :)
    Or we can supply you with an HD15 to 3RCA (F) cable to jumper the outputs from the PS2 Component cable into the HD15 input on the MXE which will accept YUV as long as the PDA-5002 card is installed - assuming you dont use the HD15 for a PC that is.
    Best regards
    Joe
  5. nealgs
    nealgs
    has your sky box got two SCART sockets?? you might be able to daisy chain your PS2 to the SKY box, which then feeds the RGB2YUV box
    E.G
    PS2->SKY->RGB2YUV->AMP->Panel
    We also have the MXE, and hope to be getting an XBox shortly, so may have a similar connection problem (although do have one set of components ins left on AV reciever
    Link to review of Zektor unit that Joe's on about
    http://gear.ign.com/articles/452/452131p1.html?fromint=1
    regards
    Gary
  6. daveb975
    daveb975
    Oct 25, 2002
    4,328
    103
    London
    +368
    I was planning to connect my PS2 by S-Video. I have not tried it yet - will the image quality be acceptable?
  7. Epoman
    Epoman
    Jan 3, 2002
    3,128
    71
    On my PC
    +85
    THanks for the tips guys. I've had a few more problems so I've started a new thread.
