Connections problem
Discussion in 'Satellite TV, Sky TV & FreeSat' started by David, Aug 6, 2003.
  1. David
    David
    Nov 26, 2002
    221
    16
    London
    I seem to have a connection problem. My Thompson digibox is connected by scart direct to the TV and also by scart to the video recorder. The Video recorder is connected to the TV through an S-Video cable. (A DVD Player is also connected direct to TV by scart). The digibox plays perfectly well to the TV as long as the video recorder is off. As soon as I turn it on the signal is interrupted by what I assume is some sort of video feedback. Any easy solutions?
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    I wonder if the AV input on the TV actually assigns the scart input from the digibox and the s-video input from the VCR as a single source and it does not expect them to have active signals on both inputs.
    Have you tried disconnecting the s-video and allowing the VCR output to be passed through the digibox and into the TV?
  3. David
    David
    Nov 26, 2002
    221
    16
    London
    I haven't tried that but will. Thanks
