Connections on Panny 6
Discussion in 'Plasma TVs Forum' started by kbillyard, Nov 18, 2003.
  1. kbillyard
    kbillyard
    Jan 14, 2003
    25
    London
    Sorry about this guys, novice question...
    Looking at the Black Panny 6 and it comes with the TY-42TM6Y board, which is BNC and Svideo, and Component.
    However when looking at the board there are 5 BNC Connectors for the the Component, I thought Component was only three, what are the other two for ???
    I am keen to buy one of these but I need to know what cable to get ....
    Karl
  2. lovegroova
    lovegroova
    Jul 15, 2002
    2,692
    103
    Herts
    +384
    I think they are for sound.
  3. PhilJW
    PhilJW
    There are certainly only 3 bnc component connections for the video.
  4. howies
    howies
    they are not for sound . i think they are horizontal and vertical sync. from a dvd player you can just connect to the usual 3
  5. codlord
    codlord
    May 17, 2002
    283
    Portsmouth, UK
    Yes they are seperate Horizontal/Vertical sync - which allows you to connect using the common component cable with 3 connections (usually Y, Cb, and Cr) or (with a setting change on the plasma) 5 connections with seperate horizontal/vertical sync (R, G, B, H, V) but not sure what devices use the R B G H V connections.
  6. lovegroova
    lovegroova
    Jul 15, 2002
    2,692
    103
    Herts
    +384
    Look here http://www.av-sales.com/plasma/html/pan_6th_gen_boards.html at the boards. The component board has 3 BNC cnnectors for the Y, Cb and Cr leads, and 2 RCA leads coloured red and white for sound. The synch comes through one of the component leads. You only need a separate synch signal when using an RGBHV connection which is done through the 15pin connector for the Panny plasmas.
  7. kbillyard
    kbillyard
    Jan 14, 2003
    25
    London
    Excellent,
    I was just a bit worried I was going to need some weird cable.
    As always a brilliant response.
    Thanks guys.
    Karl
  8. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +411
    Guys, he's being sold the original type panny universal video board, this is fine, it is RGBHV or component, switchable on the screen menu, ans shared svideo/composite. There is a separate audio in port, or ports stereo, for each input, if you are using the on board amplifier, and the audio port for the 15pin is a 3,5mm jack beside the d-sub. The d-sub input is indeed rgbhv, and also switchable to component in the screen menu. The ty42tm6y is not one of those on the av sales site, it is the board supplied with the 5 series.
  9. cwick
    cwick
    Feb 4, 2002
    2,207
    Reading
    +95
  10. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +411
    That's certainly so, but it has 2 sets of connections, so fair do's, you'd use 2 boards and 2 slots to get the same another way, exept you can now use the vga port for YUV, which you couldn't on the 5
