Connections on Hit 42PMA400
Discussion in 'Plasma TVs' started by TopMeTom, Apr 19, 2003.
  1. TopMeTom
    TopMeTom
    Sep 8, 2002
    8,228
    +261
    Hello,
    After looking at CRT's,she who must be obeyed decided too big!
    So,back on for a plasma!Was looking at the LG MZ42PZ17 ,then saw the Hit 42PMA400.
    I was wondering how you would connect all the components I have got to this? i.e:DVD player,SKY+,DVDrecorder and finally how do you watch tv?(I'm thick I know):zonked:
    Cheers,
    Phil
  2. leigh h
    leigh h
    well the Sky box can be connected by Scart rgb and composite sync to the screen, and the 2 dsub ports can be configured from rgb to component the dsub ports have a higher scan rate so you cant use any js rgb boxes or sync blaster cables but if your dvd has component then all you need is a component to dsub cable from keene and it should work.
    the dvd recorder could loop through youir sky plus or if it has component out you can use the second dsub.
  3. mw3cdj
    mw3cdj
    Nov 12, 2002
    396
    West Wales
    Hi leigh h ,
    have you tryed the component to d-sub and dose it work??
    thanks.
  4. leigh h
    leigh h
  5. mw3cdj
    mw3cdj
    Nov 12, 2002
    396
    West Wales
    Thanks for the link, looks like ill give try when i get my new pma400 Wednesday:D :D .
