Connections Advice for TW10H
Discussion in 'Projectors, Screens & Video Processors' started by noel-pilot, Jan 5, 2005.
  1. noel-pilot
    noel-pilot
    Dec 20, 2004
    Hey all,
    Getting a bit confused with connection options for my forthcoming TW10H.
    Advice would be greatly appreciated.
    I wish to connect the output from my A/V amp (currently the switching unit for my video sources, PS2, Tivo, Freeview etc) and also my Xbox.
    I had planned to run a component cable from XBox advanced connections box to projector and then run a composite cable from amp to projector. I know composite isnt very good but it will be minimal watching I think as most will be from Xbox.
    1) From other posts I have read it seems Component cables are supposed to have three cables plus a sync yet on tvcables site the component cables only seem to have the three leads?
    2) is there anyway to get a svideo signal from my tivo? Would one of those little scart plugs that have 3 phono and a s video on the back work?
    Any other advice? I would be nice not to have to keep unplugging leads each time i want to change source so be helpful if I could have composite, s video and component all plugged in a the same time!!
    Look forward to your help.
    thanks
    Noel
  2. PJTX100
    PJTX100
    Dec 21, 2004
    8,129
    +562
    RGB component has the sync but I think the sync is included on the R,G or B lead. "True" (?) component has only 3 leads. What I think I'm trying to say is that component is only 3 leads! :) ...PJ
  3. babyG
    babyG
    I'm confused about this too?????
    I thought RGB was different to componant (I have just bought my 1st projector & last night I switched my sky digibox from PAL to rgb output and the quality doubled (thru composit cable))
  4. PJTX100
    PJTX100
    Dec 21, 2004
    8,129
    +562
    It is different, it's just that you can run either RGB or component through a component lead.
    As for the digibox the RGB setting is the best if using a connection capable of carrying it.
    My "expertise" in these matters is being stretched here, I'm sure others know much more detail!
    cheers...PJ
