connection...
Discussion in 'Xbox Forums' started by djmetsandy, Aug 4, 2006.
  1. djmetsandy
    djmetsandy
    Jul 30, 2006
    947
    Perth, Scotland
    +35
    does anyone know if you can plug your xbox 360 to the PC to gain the connection of broadband from it? if not i will have to trail 70 odd miles to buy a old wireless router and pick up my wireless adapter from my house!
  2. madfish_den
    madfish_den
    Yep, it's your manual, y'know that thing that gets in the way of you getting the 360 out of the box!
    alternatively, check out shadowmanuk's great site : www.xboxlivetheguide.co.uk
    denny
