connection type on a Panasonic TH42PW6
Discussion in 'Panasonic TVs Forum' started by daz500, Oct 12, 2004.
  1. daz500
    daz500
    Oct 10, 2004
    47
    Belfast
    please help ...
    I managed to pick up a TH42PW6 plasma from my local Richer Sounds branch but now I have a problem. I've been reading through the forums but I seem to be going around in circles. What is the best connection board to use for getting a video display on the plasma screen?
    I'm going to buy a progressive scan DVD player so it will have component output and I already have Sky+ (I gather I need to buy a JS device for coverting scart into component)
    I would like to use my Denon A1 amp to switch component video so that way I can easily change the output from the plasma to the projector.
    I guess the question is .... do I buy a component input board for the plasma or do I buy a cable which has component connectors on one end and has the VGA d-sub connector on the other using the AMP to provide a component video signal in both cases?
    thanks in advance,
    darren
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    go for the cable and JS RGB>YUV Box, AV-sales should be able to supply both for you.....
