Connection Question.
Discussion in 'Cables & Switches' started by ehjay, Aug 27, 2004.
  1. ehjay
    ehjay
    I'm trying to connect an Apple G5 to our projector, while maintaining the connection between the Apple and it's monitor.
    I've never projected before using the G5, so if you can tell me that this setup will also mirror the screen so that the monitor still displays the desktop, as well as having it output to the projector, that would be gold.
    Anyhow. The Apple Monitor is a brand new 20", with a DVI connection. The projector uses S-Video or Composite, and the only adapater I've seen for the Apple is a DVI-to-video adapter that Apple sells.
    The computer has an ADC port and a DVI port. Should I convert either one of these to ADC, and then will it work properly and how I want it to?
