Connection query for XLS200
marcstang
FInally got my XLS200. Connected it via the low level input inputs to my Sony amp and it sounds great.
I was wondering if it was possible to connect the centre speaker output to the XLS via the high level inputs to boost the bass from the centre a bit more ? Has anyone done this ? Any explanation, diagram, or picture how to connect it would be appreciated.
joffy1780
If you have your centre speaker set to 'small' in your settings,your receiver will be sending all of its low bass info to the sub anyway.
Interesting idea though,but I reckon 2 subs would be the way to go.
joffy1780
Thanks for that. Gues I just want to use that high level connection somehow :devil:
If you have a separate stereo amp running your fronts,the x-over bypass switch would be very handy.Assuming you don't have a separate stereo amp,that is one way to utilise the high level connections in the future(if you're really desperate:devil: )
⭐ Philips OLED+908 TV preview + Avid Accent amplifier reviews + Hi-Fi & AV News
Back
