Connection Problems with AV Amp
Discussion in 'AV Receivers & Amplifiers' started by kav, May 16, 2001.
  1. kav
    kav
    I want to know if I am best running all of my video sources through my AV Amp and then from my amp to the TV. Or, should I connect my video sources direct to the TV and just take the sound output to the amp.
    Also if I run everything through the amp, does it matter if I mix component and s-video terminals and then just run an
    (s-video cable to scart) to the TV.
    :confused: :confused:
  2. Nike
    Nike
    Feb 27, 2001
    667
    bournemouth, UK.
    +20
    Check the thread 'HCC & WV&TV Why a difference in advice' posted by John wilks in General Chat.
    Not sure about mixing connections, I've not ever routed video signals through my amp -
    Sure someone more knowledgeable will reply though
  3. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    I route the video signals through my Sony strdb940 for convenience but having tried the dvd direct to the tv and routed through the amp i cant see any improvement with the direct route on my 56" tv. ;)
  4. bighairy
    bighairy
    Short answer: yes it matters.
    If you connect an S-video source to the amp then you will see nothing on the composite video output and vice-versa. Either connect everything in S-video or make sure that the output to the TV is both S-video and composite.
    (Unless there are some fancy switching amps out there that do convert composite to s-video, but I've not seen them!)
  5. MarkB
    MarkB
    Oct 29, 2000
    737
    Suffolk, England
    +26
    Apparently, new Denon machines will have the ability to convert backwards and forwards between Composite and S-Video internally, automatically. Don't suppose that helps much at the moment!
    Mark
  6. kav
    kav
    Thanks for the advice.
