Connection problem?.....please help?
E
eightball
My friend has just purchased a Toshiba 28Z23 TV & SD-42HK DVD, the SD-42HK does not have a scart connector but has component, composite & S-video. The TV has only two scarts, one RGB & one S-video. What we need to know is it possible to get a component to RGB converter, or is it better just to use S-video, to connect the DVD & TV.
My DVD's
kevenh
Looks like you can get RGB out of the SD42?!
Look Here.
The connections pop up is unviewable, but RGB is in the specs.
I guess you need an RGB to SCART lead.
kevenh
They don't show a scart connector on the back view, but keep writing about one!!
"SD-42HK
• DVD Video Player • Dolby Digital/DTS/Dolby Pro-Logic/MP3 Decoder
• Digital PLL FM/AM Tuner (30 Presets) • 210W RMS Audio Output • MP3 Playback
Additional features:
• 6 speaker package (2 main, 2 surround, 1 centre, 1 passive sub woofer)
• Digital amplifier
• Headphone jack
• SCART
• Optical digital audio input
• S-video output
• Analogue audio input
• Component video output
• Composite video input and output
• Plays: DVD, CD, VCD, CD-R, CD-RW, MP3"
This info came from here.
E
eightball
i have seen the player it does not have a scart connector, & if does output RGB we do not know how.
kevenh
I am a little concerned at the difference between what I see the SD42 looks like at the Toshiba's site, and what Toshiba describe it will have :confused:
That column of 'Video 1 Out' connections, is there a menu setting that would let you alocate them to RGB?!!
Going component to RGB is the wrong way for the common HC setups.
rgbtosvideo have RGB to YUV, :devil:
And I've no idea where Tosh have hidden the scart connector.
soz!
E
eightball
i will go though the menu tonight, when i see my friend.
