Connection options for TH37PW7 plasma
Discussion in 'Plasma TVs' started by Fossil, May 29, 2005.
  1. Fossil
    Fossil
    May 29, 2005
    105
    +5
    Hi all another newbie here who knows little about plasma screens but is looking for advice on best connection options for my intended setup.
    Current setup, running MCE from our office PC via composite video/audio cables through 2 walls to a scart adaptor into CRT.
    Likely to purchase a Panasonic TH37PW7 from Richer Sounds (don't need a tuner as we have a tuner in the pc) but the problem is how to connect achieving the best quality, I understand I can use the current audio cables for sound and best video quality is via VGA but I don't really want to drill massive holes through the walls to take the large vga plugs.
    Is there any way round this?
  2. Fossil
    Fossil
    May 29, 2005
    105
    +5
    Anybody?
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    try searching for threads by lisag she has the 37" and Media PC
  4. Fossil
    Fossil
    May 29, 2005
    105
    +5
    Thanks for the reply Horny Dragon, much appreciated.
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    also VGA is actually RGBHV and you can use comething like Van damme mini coax 5 cores to carry VGA throught he walls (will need a steady hand to solder it at the other end though!
