I am trying to connect my NC-10 netbook to my Samsung TV, which I seem to do fine with a 'normal' length VGA cable, the problem is it isn't very long and not very convenient, so I purchased and tried a 5 metre cable - it didn't work. Assuming this cable was faulty I have now tried a VGA extension (2 metres long) again this does not work.
When using the shorter cable I have not had to change any settings on either the netbook of the tv - the tv just detected the NC=-10 and the 'PC' screen came up when the source button was pressed on the remote.
Any suggestions?
Any suggestions?
