Connection Help
Discussion in 'AV Receivers & Amplifiers' started by brothereidos, Sep 2, 2001.
  1. brothereidos
    brothereidos
    I have a Samsung 709 DVD Player with Digital Coaxil output and a Sony HTK 170 Home Cinema Kit with 6 AV Inputs - Is there a way of connecting the 2. <img src="confused.gif" border="0">
  2. Doubledoom
    Doubledoom
    The 6 channel inputs would only be used if you wanted the dvd player to do the dd5.1/dts decoding which may not be present on your amp.
    Does the amp not have a co-ax input?
  3. brothereidos
    brothereidos
    No my amp has 3 sets of left\right audio inputs fot t.v. video etc & 1 set of six audio inputs for 5.1 dvd.
  4. Doubledoom
    Doubledoom
    I don't know your model so i need a bit more info.
    Does the amp have onboard DD5.1/DTS decoding or is it a DPL amp?
    If DPL (which i am guessing it is from the lack of a digital connection), you need to get the dvd to do the decoding. I don't know if your dvd player has an onboard decoder but if it does, it would have 5.1 outputs to go to those 5.1 inputs on the amp.
