Connection help with Panny E65
Discussion in 'Blu-ray & DVD Players & Recorders' started by alan5757, Dec 28, 2004.
  1. alan5757
    alan5757
    Mar 23, 2004
    182
    +22
    Help needed. Bought Panny E65 yesterday. Having trouble getting progressive scan image on projector.
    Ended up disconnecting all scarts from the back. Just had component leads connected and put in a pre-recorded dvd. Video setup on AV1 was set to Video (with component) also tried s-video (with component). Also had progressive scan set to On.
    Projector received no signal.
    Anybody got a Panny who can help. Lead length is 15m. Although I am aware image degredation will occur the greater the cable length, shouldn't stop progressive signal should it? Component works ok with progressive set to Off.
  2. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    Dumfries, SW Scotland.
    +9
    Silly question, Alan, I assume the Projector is Progressive enabled.....
    Jimmy
  3. alan5757
    alan5757
    Mar 23, 2004
    182
    +22
    Yeah Jimmy - thanks
    Have tried it out on a friend's plasma and Panny is fine - must be a projector or adaptor issue. There is a special VESA adaptor for component progressive with my projector - maybe that.
    Panny is fine - thanks
