Connection help required
Discussion in 'AV Receivers & Amplifiers' started by conington, Mar 6, 2002.
  1. conington
    conington
    Mar 6, 2002
    259
    Colchester
    +6
    I am a little concerned that I am not getting the best out of my system ..... I am using an LG 3350 with optical lead to a Yam amp (Speakers = Mission 702 front left and right with Mission centre speaker and Yams for the rears), the setting on the DVD player is for bitstream, should I re-set this to Dolby Digital (my amp is showing Doby digital under the bitstream setting) ?
    I have the DVD picture sent via SCART to the second (non RGB) scart on my rear projection Toshiba television, the first (RGB enabled) being used for my digibox. If I push the DVD SCART through the Digibox I can of course benefit from the RGB (which I must say does not seem to make a lot of difference to the picture quality??), on the DVD there does not seem to be a setting for RGB although I have read that RGB is catered for .... any suggestions on the best routing and settings here ?
  2. Jase
    Jase
    Mar 16, 2001
    10,822
    United Kingdom
    +2,714
    Leave the Bitstream setting, thats ok.
    You could always try S-Video if you dont think the RGB setting is giving you the best picture (you´ll probably have to change the TV setting as well as the dvd player).
    Or just run the dvd via the digibox as you said.
    cheers
