Connection Help Please for a noob :)
Discussion in 'AV Receivers & Amplifiers' started by ScoobyZ, Oct 22, 2003.
  1. ScoobyZ
    ScoobyZ
    Sep 29, 2003
    915
    +55
    Hello I have taken delivery of my first Home Cinema Setup.
    I have gone for a set of Tannoy FX1 speakers inc Sub / 2 Stands (£238) and a Denon 1603 reciever (£149) which I though was a good deal.
    AMP REAR PIC: http://www.avland.co.uk/denon/avr1603/index.htm
    Just curious the best way to connect my DVD and other bits, itv digital box / video to the amp. It looks like I just need standard phone cables (the red / white ones)
    DVD REAR PIC:
    http://www.afterhours.co.uk/cgi-bin/SHPLoader.cgi?/Shop/402.htm
    I have worked out I need a sub cable (dooh) and was thinking of getting one from here:
    http://www.audiovisualonline.co.uk/dynamic/eshop_categories.set/ref/10/browse.html
    Any other tips advice recommendations, appreciated
    Scooby
  2. Dom36
    Dom36
    Aug 26, 2003
    285
    Good ol' UK
    +6
    Yea just plug a red and white into the DVD leading to the Amp and that will work fine...
    You could go optical but I personally don't think it's worth the money...
  3. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    Use coax digital for the DVD connection, 2-channel analog for set-top box etc.
    Digital is always preferred over analog, coax is better than optical if at all possible.
  4. SanPedro
    SanPedro
    Jan 11, 2001
    4,503
    +504
    Wouldn't these just be stereo leads?
    Chris
  5. Jase
    Jase
    Mar 16, 2001
    9,466
    South Coast
    +891
    If you don't want Dolby 5.1 or DTS.:p Unless you're talking about just using one bog standard red & white cable and using it as a digital coaxial lead. The standard red & white cables are crap, although you don't need to spend crazy money to get decent cables, check out the DIY section.:)
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    Dont bother connect viodeo to the amp and usel digital coax for DVD Digital if ITV box has it and stereo red/white (might want to try some better ones) for VHS.
