Connection help needed
Discussion in 'Projectors, Screens & Video Processors' started by Jerome, Jan 11, 2002.
  1. Jerome
    Jerome
    I will soon have a 16:9 Sony 400 PJ. First PJ for me & so I could do with some help!
    I have a Rotel 995 DVD & the old RSP966.
    Looks like s-video/RCA compsite O/P from the RSP only, but obviously the 995 has digital & component etc
    Question is, what cables/format should I use to connect the DVD to the RSP & the RSP to the Sony PJ?
    Apologies if this seems a total HC novice question - but then that's what I am!
    Thanks.
  2. Guest
    Jerome
    If you mean the SONY VPL-W400Q, it's been a least 4 years since I actually saw one. If I remember correctly it has composite, s-video and RGB 15pin but can not eccept component input!
    I would go for s-video 1st as the cables will be much easier to come by and cheaper. If you are happy with that then great, if not, then try to get a suitable RGB scart to 15pin. I have seen this work on several projectors, but not all.
    I don't know what an RSP966 is so I can't comments on that!
  3. Jerome
    Jerome
    thanks for that - I will probably start off using s-vid to & from the processor in that case... and then probably end up posting loads of questions about tweaks!
  4. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,441
    Somewhere in South Yorkshire
    +5,852
    There is a huge discussion forum devoted to the Sony 400QM at www.thebigpicturedvd.com
    along with FAQ and other stuff. You should find more than enough info to keep you tweaking for months there.
