Connection help need on my pw6 and sony dav-s400
Discussion in 'Sony TVs Forum' started by 2naughty4u, Apr 6, 2005.
  1. 2naughty4u
    2naughty4u
    Mar 22, 2005
    26
    London
    Hi guys
    Ive got a panny pw6 and a sony compact av system dav-s400 (home cinema system)
    I looked at the back of the dav-s400 and the connections are as below:
    [​IMG]
    I wanted to connect this to my pw6 through the pc input and I was wondering if the van damme/bettercables VGA to 5 RCA (RGBHV) cable is the right one to connect everything together? :confused:
    [​IMG]
    If this is not the right way to set everything up, please could you give me advice on the best way to do it all without loss of pq? :lease:
    thanks in advance
    :devil: 2naughty4u :devil:
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    sorry 2naughty4u........but that sony system has to go it only has composite output for DVD the worst quality.....that lead wont work either (not with that crappy DAV system...)
    something like this is much better http://www.avland.co.uk/denon/dht500sd/dht-500sd.htm
    but there are even better ways.......Pio 575 VCXS402 and canton CD1 cost around £500 are will offfer much more flexibility and PQ
  3. 2naughty4u
    2naughty4u
    Mar 22, 2005
    26
    London
    Thanks Hornydragon :smashin:
    Theres no point in getting rid of the dav s400 as i'll only get £40 for it
    I ended up buying the panny dmr e55.
    Is there anyway or the best way to connect up the e55 to the dav s400 only for surround sound purposes?
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    yes connect optical from E55 to DAV400 for 5.1 etc
  5. 2naughty4u
    2naughty4u
    Mar 22, 2005
    26
    London
    cheer hornydragon
    you are the master of all plasma knowledge :lesson:
