connection headaches, please help
Discussion in 'Cables & Switches' started by spiderdany, Apr 1, 2005.
  1. spiderdany
    spiderdany
    Hey there
    Can anyone help me with the following as Im pretty confused about the whoel thing really:
    I have a philips 26pf8946 lcd tv - with an awful manual incidentally - it has dvi in port, 2 scart ports (ext 1 and ext 2) and a vga in and an s video port.
    I have a Pioneer dv-575A dvd player which I want to connect to the lcd tv - this has a progressive scan feature which Id like to take advantage of - it has component video out ports, scart port and s video port.
    Whats the best connection to use?
    Would I best off with a standard scart to scart connection? or would I be able to use a lead connecting scart on the tv to the component video ports on the dvd player (with two different ends) ?
    Any help is much appreciated - thanks : )
    Spiderdany
  2. GreenBars
    GreenBars
    Oct 29, 2004
    631
    Hertfordshire
    +23
    From the information you have given, it is unlikely that your TV can accept a component video signal. Best bet would be to use scart, setting the DVD to output an RGB signal and the TV to accept an RGB input.
  3. elementalist2
    elementalist2
    Mar 28, 2005
    200
    An LCD can probably make use of progressive scan - I would phone Keene Electronics - they do good equipment and have expert advice.
