Connection Doubts: HD + Surround Sound
Discussion in 'LCD & LED LCD TVs Forum' started by dutchgraham, Sep 14, 2007.
Tags:
  1. dutchgraham
    dutchgraham
    Dec 15, 2006
    70
    +6
    Probably a stupid question, but I'll ask it anyway!
    I have an existing HD box connected to a Samsung R74 with no surround system, but want to replace the TV with a Sony 40D3000 + Sony home cinema system (DAVDZ630 or 830?). Would I need to connect the HD box to the amp via optical cable, or is it sufficient to connect it to the TV only via HDMI and let the Sony units sort out the surround sound?
    If I need to connect it to the amp, obviously I will have to buy one with an optical in, which pretty much steers me towards the DAVDZ830 (at £150 dearer than the 630).
    Thanks in advance for any advice.
  2. dutchgraham
    dutchgraham
    Dec 15, 2006
    70
    +6
    Surely someone knows the answer to this?
  3. nitro23456
    nitro23456
    Jul 30, 2007
    293
    Resident Panasonic LXD70 Expert
    +15
    optical input required for dolby digital. pro logic wont require this.
  4. dutchgraham
    dutchgraham
    Dec 15, 2006
    70
    +6
    Does that mean I won't need any direct connection between the HD box and the amp, i.e. will the audio going from the HD box to the TV be 'picked up' by the amp and broadcast as surround sound?
