Connection Confusion
Discussion in 'Cables & Switches' started by superted, May 3, 2005.
  1. superted
    superted
    May 3, 2005
    3
    Hi There,
    I have purchased a new Plasma tv and require some advice from your goodselfs on cabling.
    Its a Daewoo D42sp and has the following connections :
    2xscart (through a external reciever unit
    1 HD compatible component input (has five connectors that look different to RCA style jacks i was expecting) and a seperate component in so the 3 colours and 1 audio inputs. also has a few other connectors but not fussed with those at the moment.
    Basically i need to connect 1 xbox,1ps2 and one dvd system to this setup possibly sky+ soon as well, Now i undserstand xbox is hd compatible on some games and both consoles would benefit from component input rather than the scart they are on now?
    I took a look and a xbox hd tv av pack can offer xbox hd compatibility through the component leads http://www.whitedog.co.uk/catalog/product_info.php?products_id=626
    That sounds perfect and once i connected it to the pack in the xbox pref i can selecr 1080i apparently.
    Would this cable offer the same compat? http://www.whitedog.co.uk/catalog/product_info.php?cPath=3_59&products_id=397
    Whats best for SKy+ also does it only offer scart?
    ANy help advice on my situation would be appreciated
    C
    Ed
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    SKY+ offers RGB+S and composite via Scart coinnectors as well as S-video, RGB+S can be convetered to component for about £150 using a converter box. connecting the all via componet is a good idea if you can switch the component sources (via AV amp for example) to the palsma Component (YUV/YPbPr) inputs
