Connection Confusion
Discussion in 'Projectors, Screens & Video Processors' started by Scoobycity, Dec 21, 2004.
  1. Scoobycity
    Scoobycity
    Dec 13, 2004
    34
    I've just got my first projector. Its a Misubishi UL5 (LCD, XGA 1700 Lumens) which I'm over the moon with.
    I want to run an NTL Cable TV box, an XBox, a DVD player and my PC through it and eventually have it roof mounted.
    On my old set-up I just had a three scarts into one adaptor then into the back of a rear projector TV but the only video inputs on the projector is composite and s-video.
    After doing some research on here it looks like I should be using component connections but unless theres some sort of adapter available to plug into the PC socket I can't see how I would plug the 3 components and if I did I would use up the PC input needed for my PC.
    The only other way I can see is to plug a scart to S-Video converter (shown below) into the output from my 3-way scart box and into my PJ but surely this is a "bodge"? So whats the best way?
    [​IMG]
  2. Scoobycity
    Scoobycity
    Dec 13, 2004
    34
  3. Scoobycity
    Scoobycity
    Dec 13, 2004
    34
    I can't believe you're all using these.. there mut be a better way.
    Anyone?
  4. nwgarratt
    nwgarratt
    May 5, 2002
    27,042
    +2,980
    If you don't have component then S Video is the next best.
    What woudl be better is a scart to s video cable. Then attach the scart end to the player and the S Video end to the S Video connector of the PJ. You must be able to send S Video through the scart socket.
    S Video also only does video. So, connect stereo phono (red/white) or digital audio to the audio device.
    It is possible to get just Scart to S Video as well as one with red/white phono.
    Have a look here (calls S Video SVHS which is incorrect but, they it the same thing).
    http://www.maplin.co.uk/Module.aspx?ModuleNo=35910&TabID=1&source=14&doy=13m12
