Connection confusion
Discussion in 'Cables & Switches' started by mepsipax, Sep 12, 2004.
  1. mepsipax
    mepsipax
    Mar 20, 2004
    181
    +8
    I have ordered a new TV - Toshiba 36zd26, which should be here soon.
    I could do with some help setting up all my stuff, as I am really confused about the best way to install it all.
    The TV has 3 scarts (only one RGB).
    It also has component for NTSC viewing
    I also have a Yamaha DSP 750SE Amp with loads of inputs
    Panasonic DMRE55 DVD recorder
    Sky panasonic digital box
    Xbox
    Gamecube
    Toshiba 330e DVD player
    Argos scart splitter box thing
    Not sure if there's any point in keeping the 330e dvd player in the setup, but if anyone can suggest a use for it amongst my stuff then I'll leave it there.
    My xbox connects to the Amp via an optical lead
    The way I presently have the E55 setup seems to be wrong, as the picture on my current TV is not being shown through AV1.
    I'm really not sure where the aerial cables to and from the E55 are meant to go. I seem to have tried every configuration - but no luck.
    Consequently the picture quality is not as good as it should be.
    Could really use some advice on setting this lot up PROPERLY this time!
    Many thanks
  2. mepsipax
    mepsipax
    Mar 20, 2004
    181
    +8
    TV is being delivered tomorrow so I would be grateful for any help
    Regards
