Connection configuration components help needed
Discussion in 'Cables & Switches' started by CastNoShadows, Apr 26, 2007.
  1. CastNoShadows
    CastNoShadows
    May 28, 2005
    4
    I am shortly to be changing an old CRT for [probably] a Panasonic TH42PX600P or very similar. Other components will be a Sky HD box and a PS3 [which will be DVD & BluRay player].
    I will not be having a home cinema speaker set up but will want to put all the audio signals through my hi-fi amp [which I do currently via phonos].
    Can anyone advise me of the setup I will need to do this to achieve best quality sound/vision - for instance will I need a switcing box of some sort to bring together the different sound sources?
    I can't find this info on the site but if it's there please direct me and apologies.
    Cast
  2. Stung
    Stung
    Dec 4, 2006
    183
    +14
    If I'm not mistaken, the panny has 2 HDMI sockets.
    1. Connect Sky HD and PS3 to TV using HDMI cable.
    2. Phone cables from PS3 and Sky HD to amp.
    Done.:smashin:
  3. ows90
    ows90
    Jun 19, 2006
    322
    28
    +60
    2x HDMI, as Stung says for the Sky HD and PS3.
    However for audio, the manual -- available from http://www.panasonic.co.uk/customer-Support/download-centre.asp -- shows a L R phono output on the back of the TH42PX600; it should output whatever audio accompanies the currently viewed input, be it PS3, Freeview or Sky HD. So you shouldn't need a switching box.
  4. CastNoShadows
    CastNoShadows
    May 28, 2005
    4
    Thanks chaps. Much appreciated. No problems then. although I have always thought that a signal from the source would provide better quality than one routed through TV. Would only need one set of interconnects through TV. Any suggestions on quality I should be looking for?
    Cast
