connection/ board help. th37pw7
Discussion in 'Plasma TVs Forum' started by ajinlondon, Apr 5, 2005.
  1. ajinlondon
    ajinlondon
    i have got the js rgb converter, and sky (normal) and a sony dav s500
    without spending anymore on dav replacement,
    what board do i need to buy ? i also will be getting sky+ soon is there any difference in the connectors avail in the back?
    i have searched this forum but everytime i think i have a solution another thread says otherwise..
    a simple board name that will accept the dav would be a grt help for starters
    thanks
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    does DAV not have RGB Scart? (or even better component) if it only has S-video out you need a Video board for the panny:
    TY-42TM6V
    or
    TY-42TM6BB
    LAtter is £85 from AV-sales
    SKY+ has RGB scart and S-video (use RGBscart for best results)
  3. ajinlondon
    ajinlondon
    the output is RCA -(the red /yellow/ white ones) but when i plug into the JS rgb i get no picture.
    i assume this is the scart adaptor thing that i have on the end of the phono connectors..?
    and if i get one of the above boards will this allow me to upgrade the dav in the future without chaning the board?
    thanks
  4. ajinlondon
    ajinlondon
    so as per my Q above if i get the above board and i change the DAV , will the board then be a waste of ££ i assume component is what i really want in the end..
  5. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    sounds like the output is composite (3 rca leads) so it wont work with the the js....and if you changed the dav it's unlikely you would still need a composite input...but you never know...you may do at some stage so maybe the dual component / composite board is teh best bet
  6. ajinlondon
    ajinlondon
    will the dual baord still work in the 37" with the only 2 slots avail?
    i guess then i have no option for HD if there is an option coming..
    but then again i guess the cost of the 2 boards is not much diff to the dual board? in the long term if i caount selling the second hand board for tuppence in the future..
  7. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    well it will take both slots of course......you could just buy the bnc component board (1 slot)....range between £60 - £80...whereas the rca version is loads more just because its the 'consumer' version.
