Connection bleeping!!
Discussion in 'General Chat' started by saucer, Sep 24, 2005.
  1. saucer
    saucer
    I have the wireless Netgear for my laptop which is Windows XP. When the connection is sometimes lost then reconnects I get an annoying chime ringing! :mad: How can I turn that off? I know there must be a way on the sound devices. Thanks in advance.
  2. The Dude
    The Dude
    May 21, 2004
    5,210
    Beverley, East Yorkshire
    +1,520
    it's 'device connect/disconnect' in the sound scheme.. ;)
  3. saucer
    saucer
    Cheers for that 'Dude', but I am still getting that bloody bleeping! :mad: Can you be more specific on what you have to do.
    Many thanks
  4. pragmatic
    pragmatic
    Nov 9, 2004
    12,120
    +1,678
    Control panel > Sound and audio devices > Sounds
    find the 'device connect/disconnect' sound from here and either remove it or replace with something you'd rather have.
    Otherwise mute your pc, as that'll do the job too :p
