The handbook of the receiver says: 'Wherever possible, connect both the analogue and digital outputs of digital sources', while the handbook of the cd-player says: 'Optical digital output: use this socket if you are using a separate DAC or digital recorder'.
So, if I understand it well, the DAC of the receiver will be used, instead of the DAC of the player, should I make a digital connection.
I wonder which solution would give the best sound results. Can anyone inform me on this ?
