connection advice
Discussion in 'Plasma TVs Forum' started by rdt123, Feb 15, 2003.
  1. rdt123
    rdt123
    Dec 14, 2002
    1,423
    Busting out a restaraunt in Queens, NY
    +33
    Am getting a 42" panasonic 5 series
    I will have a progressive scan DVD player and expected to just have to use a component cable from the player to the display and maybe s-video form the sky+ box. Is this right? The number of posts on connections to plasmas is making my head hurt!!
    TIA
    Rob
  2. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    Hi Rob,
    Yes, what you are proposing would be fine. Are you intending to fit a terminal board or get a tuner? I'd suggest that an RCA or BNC terminal board would be preferable as the Sky+ box would serve well as your tuner. Hope this helps.
    Steve
  3. rdt123
    rdt123
    Dec 14, 2002
    1,423
    +33
    Does this mean i need to by this terminal board after buying the display?
  4. Hinch
    Hinch
    My Panasonic 37 came with the RCA component board which is good for componant and RGB+HV oh and also svideo. The board was boxed separately but I'm sure it wasn't a mistake.
    Ian
