connection advice
Discussion in 'AV Receivers & Amplifiers' started by garye, Oct 1, 2001.
  1. garye
    garye
    i have connected sony str-de445 to tv via audio leads but am confused as to how i connect digibox as there is only one tv/sat input on receiver. At the moment i have the digibox connected to the aux.<br />please advise on best way. <img src="confused.gif" border="0">
  2. Jase
    Jase
    Mar 16, 2001
    10,804
    United Kingdom
    +2,693
    Just leave it as it is or connect the tv to the aux and the digibox to tv/sat.
    It wont affect the sound quality.
    cheers
  3. Doubledoom
    Doubledoom
    I agree.
    You should be able to hear the audio from the digibox via the tv. Remember the scart carries the audio from the digibox to the tv as well as the picture.
    You can connect the 2x phono output from the digibox to the amp to see if there is any difference but hopefully, your tv will pass the audio with no sound loss (my current and previous Toshiba tvs did)
